20 years agohow to use "msgget" in nios2 uclinx?
hi:
I use function ret = msgget(KEY_MQ_CORE, IPC_CREAT|0660); make successed. After exec, but the return value is -1 I want to use cmd "IPCS" to check the ipc ID. but shell return: not found. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif How can I do? The same function "msgget" used in other uClinx os is OK. Why failed in nios2 uClinux? Why the cmd "IPCS" not support nios2 linux? Thanks a lot.
