20 years ago
How to use interrupt?
Hello.
I want to use interrupt from USER_PIO, but I don't know how to use.
I tried this sample code , but it seems that ISR is not executed.
(I modified two point.
*definition of CYGNUM_HAL_INTERRUPT_1
*add printf into ISR )
What is wrong?
How can I solve it?
This may be very primitive question, but I'm really newbie.
Please help me.
Thank you.
#include <cyg/kernel/kapi.h>
static cyg_interrupt int1;
static cyg_handle_t int1_handle;
static cyg_sem_t data_ready;
# define CYGNUM_HAL_INTERRUPT_1 USER_PIO_IRQ  //Changed# define CYGNUM_HAL_PRI_HIGH 0
// Interrupt service routine for interrupt 1.
cyg_uint32 interrupt_1_isr(
           cyg_vector_t vector,
           cyg_addrword_t data)
   // Block this interrupt from occurring until
   // the DSR completes.
   cyg_interrupt_mask( vector );
   // Tell the processor that we have received
   // the interrupt.
   cyg_interrupt_acknowledge(vector);
   printf("ISR\n");    //changed
   // Tell the kernel that chained interrupt processing
   // is done and the DSR needs to be executed next.
   return(CYG_ISR_HANDLED | CYG_ISR_CALL_DSR);
   // Deferred service routine for interrupt 1.
void interrupt_1_dsr(
          cyg_ucount32 count,
   // Signal the thread to run for further processing.
   cyg_semaphore_post(&data_ready);
   // Allow this interrupt to occur again.
   cyg_interrupt_unmask(vector);
// Main starting point for the application.
void cyg_user_start(void)
   cyg_vector_t int1_vector = CYGNUM_HAL_INTERRUPT_1;
   cyg_priority_t int1_priority = CYGNUM_HAL_PRI_HIGH;
   // Initialize the semaphore used for interrupt 1.
   cyg_semaphore_init(&data_ready,0);
   // Create interrupt 1.
   cyg_interrupt_create(
      int1_vector,
      int1_priority,
      0,
      &interrupt_1_isr,
      &interrupt_1_dsr,
      &int1_handle,
      &int1);
   // Attach the interrupt created to the vector.
   cyg_interrupt_attach(int1_handle);
   // Unmask the interrupt we just configured.
   cyg_interrupt_unmask( int1_vector);
    your thread runs once and then dies
    you need a infinite loop in
    static void ledglow(cyg_addrword_t data)
    while (1){
    ledpio = ledpio^0x10; //
    IOWR (LED_PIO_BASE , 0, ledpio);
    thanks i can understand,but in the following simple progamme with two thread,highest priority thread runs continuouslly ,it never dies...so here no need for infinite loop..?
    # include <cyg/hal/hal_arch.h># include <cyg/kernel/kapi.h># include <cyg/hal/io.h>
    unsigned char ledpio;
    // These numbers depend entirely on your application# define NUMBER_OF_WORKERS 4# define PRODUCER_PRIORITY 18# define WORKER_PRIORITY 17# define PRODUCER_STACKSIZE CYGNUM_HAL_STACK_SIZE_TYPICAL# define WORKER_STACKSIZE (CYGNUM_HAL_STACK_SIZE_MINIMUM + 1024)
    static unsigned char producer_stack[PRODUCER_STACKSIZE];
    static unsigned char worker_stacks[NUMBER_OF_WORKERS][WORKER_STACKSIZE];
    static cyg_handle_t producer_handle, worker_handles[NUMBER_OF_WORKERS];
    static cyg_thread producer_thread,worker_threads[NUMBER_OF_WORKERS];
    static void
    producer(cyg_addrword_t data)
    ledpio = 0x8; //
    static void
    worker(cyg_addrword_t data)
    ledpio = 0x1; //
    int i;
    cyg_thread_create(PRODUCER_PRIORITY, &producer, 0, "producer",
    producer_stack, PRODUCER_STACKSIZE,
    &producer_handle, &producer_thread);
    cyg_thread_resume(producer_handle);
    for (i = 0; i < NUMBER_OF_WORKERS; i++) {
    cyg_thread_create(WORKER_PRIORITY, &worker, i, "worker",
    worker_stacks, worker_stacksize,
    &(worker_handles), &(worker_threads));
    cyg_thread_resume(worker_handles);
    --- Quote Start ---
    while (1){
    iowr (led_pio_base , 0, ledpio);
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12630)
    --- quote end ---
    --- Quote End ---
    --- Quote Start ---
    originally posted by glecordier@Feb 6 2006, 06:31 AM
    i use the interrupt with the button pio like that:
    # include <cyg/hal/io.h> // for iowr and iord
    cyg_interrupt int_pio;
    cyg_handle_t int_pio_handle;
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12562)
    --- quote end ---
    --- Quote End ---
    Thank you, All.
    Especially GLecordier, thank you for showing your code.
    Now I can use interrupt as I expect.
    The reasons are
    (1) I tried to use printf in ISR.
    (2) I didn&#39;t unmask the interrupt.
    Thank you, very much.
