20 years agoHow to use interrupt?
Hello. I want to use interrupt from USER_PIO, but I don't know how to use. I tried this sample code , but it seems that ISR is not executed. (I modified two point. *definition of...
20 years agothanks i can understand,but in the following simple progamme with two thread,highest priority thread runs continuouslly ,it never dies...so here no need for infinite loop..?
# include <cyg/hal/hal_arch.h># include <cyg/kernel/kapi.h># include <cyg/hal/io.h> unsigned char ledpio; // These numbers depend entirely on your application# define NUMBER_OF_WORKERS 4# define PRODUCER_PRIORITY 18# define WORKER_PRIORITY 17# define PRODUCER_STACKSIZE CYGNUM_HAL_STACK_SIZE_TYPICAL# define WORKER_STACKSIZE (CYGNUM_HAL_STACK_SIZE_MINIMUM + 1024) static unsigned char producer_stack[PRODUCER_STACKSIZE]; static unsigned char worker_stacks[NUMBER_OF_WORKERS][WORKER_STACKSIZE]; static cyg_handle_t producer_handle, worker_handles[NUMBER_OF_WORKERS]; static cyg_thread producer_thread,worker_threads[NUMBER_OF_WORKERS]; static void producer(cyg_addrword_t data) { ledpio = 0x8; // IOWR (LED_PIO_BASE , 0, ledpio); } static void worker(cyg_addrword_t data) { ledpio = 0x1; // IOWR (LED_PIO_BASE , 0, ledpio); } void cyg_user_start(void) { int i; cyg_thread_create(PRODUCER_PRIORITY, &producer, 0, "producer", producer_stack, PRODUCER_STACKSIZE, &producer_handle, &producer_thread); cyg_thread_resume(producer_handle); for (i = 0; i < NUMBER_OF_WORKERS; i++) { cyg_thread_create(WORKER_PRIORITY, &worker, i, "worker", worker_stacks, worker_stacksize,&(worker_handles), &(worker_threads));
cyg_thread_resume(worker_handles); } } --- Quote Start --- originally posted by glecordier@Feb 8 2006, 06:45 AM your thread runs once and then dies
you need a infinite loop in
static void ledglow(cyg_addrword_t data)
while (1){
ledpio = ledpio^0x10; //
iowr (led_pio_base , 0, ledpio);
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12630)
--- quote end ---
--- Quote End ---
