21 years ago
how to use "creat new component"
hello :
I have designed a interface about AD574A. and I want the nios to communciate with AD754 through the interface Now I want to fit the interface to the component tool of SOPC Builder . then I use the "creat new component " and add the HDL file of AD574, but I don't how to choose interface for ports.
the HDL file is bellow:
library ieee;
use ieee.std_logic_1164.all;
entity ad574 is
generic(width:integer:=12);
port(D :IN STD_LOGIC_VECTOR(width-1 DOWNTO 0);
CLK ,STATUS : IN STD_LOGIC;--CLK : clock of AD574's state-machine£¬STATUS:status of AD574 conversion
CE,CS,A0,RC,K12X8 : OUT STD_LOGIC; --AD574's controlling signal
Q : inout STD_LOGIC_VECTOR(width-1 DOWNTO 0));
end ad574;
architecture behav of ad574 is
type state is (st0, st1, st2, st3,st4);
signal current_state,next_state :state:=st0;
SIGNAL REGL : STD_LOGIC_VECTOR(width-1 DOWNTO 0);
SIGNAL LOCK : STD_LOGIC;
begin
K12X8 <= &#39;1&#39;;
process(current_state,status)
begin
case current_state is
when st0 =>CE<=&#39;0&#39;;CS<=&#39;1&#39;; A0<=&#39;1&#39;;RC<=&#39;1&#39;;LOCK<=&#39;0&#39;;next_state <= st1;
when st1 =>CE<=&#39;1&#39;;CS<=&#39;0&#39;; A0<=&#39;0&#39;;RC<=&#39;0&#39;;LOCK<=&#39;0&#39;; next_state <= st2;
when st2 =>CE<=&#39;1&#39;;CS<=&#39;0&#39;; A0<=&#39;0&#39;;RC<=&#39;0&#39;;LOCK<=&#39;0&#39;;
IF (STATUS=&#39;1&#39;) THEN next_state <= st2;
ELSE next_state <= st3;
END IF ;
when st3 =>CE<=&#39;1&#39;;CS<=&#39;0&#39;; A0<=&#39;0&#39;;RC<=&#39;1&#39;;LOCK<=&#39;0&#39;; next_state <= st4;
when st4 =>CE<=&#39;1&#39;;CS<=&#39;0&#39;; A0<=&#39;0&#39;;RC<=&#39;1&#39;;LOCK<=&#39;1&#39;; next_state <= st0;
when others =>CE<=&#39;0&#39;;CS<=&#39;1&#39;; A0<=&#39;1&#39;;RC<=&#39;1&#39;;LOCK<=&#39;0&#39;;next_state <= st0;
end case;
end process;
PROCESS (CLK) BEGIN
IF ( CLK&#39;EVENT AND CLK=&#39;1&#39;) THEN current_state <= next_state;
END IF;
END PROCESS ;
PROCESS (LOCK) BEGIN
IF LOCK=&#39;1&#39; AND LOCK&#39;EVENT THEN REGL <= D ;
END IF;
END PROCESS ;
Q <= REGL;
END behav;
I have design :
D: export avalon_slave
CLK :clk goble_signal
STATUS :export avalon_slave
CE,CS,A0,RC,K12X8 :export avalon_slave
Q:readdata avalon_slave
but when I use the new component "AD574_0" in the nios system , I found the AD574 cannot connect to any slave bus ,and "generate" is failure.
how can I do ?who canhelp me ?
