dsun01
Contributor
4 years agohow to uninstall Nios II eclipse
Dear Support,
I have trouble to run the Nios II eclipse properly, you can see the problem detail here.
Re: Template is empty in the Nios II application and BSP from Template - Intel Communitie...
- 4 years ago
We recommend that you uninstall everything completely, and reinstall everything again completely. As there might be unexpected behavior if the installation is not been done correctly. If you don't see it in the control panel in the uninstall section, I believe it has been removed.
EBERLAZARE_I_Intel
4 years agoHi,
dsun01
Contributor
4 years agoThank you very much, I will follow your instruction.
