11 years agoHow to transfer doubles from the nios 2 to FPGA using the avalon interface?
Hi everyone, First a little backstory on this problem I'm encoutering. I have a Altera DE2 board on wich I want to implement my current project. In this project I need to transfer multiple ...
11 years agoThe nios is only ever going to generate 32bit Avalon cycles - so your 64bit transfer will always be two Avalon bus cycles.
Personally I wouldn't use IOW() - the semantics are all wrong and it is very error prone. You want to generate a C structure that matches your register definition (probably with some fields marked 'volatile') and 'arrange' for a pointer to do uncached accesses (possibly by getting the linker script to generate an absolute symbol). You might find it easier to dual-port an internal memory block (tightly coupled to the cpu) and use that for data transfer. The 'actions' could be initiated by an Avalon write, but you might find that a multi-cycle custom instruction is more appropriate.
