Or a combination of the two...
cat <filename> | nios2-terminal >& terminal.log You could write more elaborate scripts/code using pipes going into and out of nios2-terminal. The above is OK if batch style IO is acceptable. Do you know if it is possible to use the IO redirection tricks above to allow an existing windows terminal app to talk (tx and rx) over the jtag uart? The all the redirection examples I have seen, the data flow is one-way only. I am thinking that you would need something like a virtual serial port. - Altera_Forum
Hi
I record a tutorial on how to mount text file using NIOS II Processor and hostfs feature which enables us to mount files (such as text file) and perform read and write operation on that file http://youtu.be/kbicxwtfbiy (http://youtu.be/kbicxwtfbiy)
