How to read and write value in two different systems?
Dear everyone,
I am now working on a multicore system. cpu_0 runs uclinux, cpu_1 runs a piece of program, the base address of led_red( pio ) in the SOPCBuilder is 0x00400000, the base address of led_red in nios2_system.h in uclinux is 0x80400000. I have succeed in writing a value onto the led_red through program in uclinux, however, when I tried to read the written value through a program( cpu_1 ) without a system, it always appears the same value "-1". Here's the small program in cpu_0(uclinux).# define LEDR_BASE 0x80400000 int main(){ int *led_red = (int *) LEDR_BASE; *(led_red) = 128; return 0; } after running it in the uclinux, the 8th led_red lights on. Here's the small program in cpu_1.# include <stdio.h># define LEDR_BASE 0x00400000 int main() { printf("Hello from Nios II!\n"); int *red_red = (int *)LEDR_BASE; printf("%d",*red_red); return 0; } after running it the console always shows the value of -1 I don't know why,could somebody help me? Thanks. Yours sincerely, babysnow17 Replies
If you really want to do a shared memory region, you don't need the "flag", but you do need a hardware Mutex to allow the processors to be sure which one is allowed to write to critical memory locations e.g. to create a Mailbox mechanism: a CPU sets a bit to say: "mailbox contains data", the other CPU clears the bit to say: "data read and can be replaced" by new data. These operations need to be protected against each other. Altead SOPC-Builder does provide a Mutex on the Avalon bus for that purpose. I suppose it can issue an interrupt so that one CPU can notify the other of changes of the mailbox state.
If the shared memory is a "hardware" unit dedicated for communication, this will not slow down the CPUs, as (AFAIK) the Avalon "bus" is not a real bus, but a link between any master and any slave is created, so that accesses from two masters to different slaves can be done in parallel . -Michael - Altera_Forum
<div class='quotetop'>QUOTE </div>
--- Quote Start --- but you do need a hardware Mutex to allow the processors to be sure which one is allowed to write to critical memory locations e.g. to create a Mailbox mechanism: a CPU sets a bit to say: "mailbox contains data", the other CPU clears the bit to say: "data read and can be replaced" by new data.[/b] --- Quote End --- What is the exact meaning of CPU bit? <div class='quotetop'>QUOTE </div> --- Quote Start --- These operations need to be protected against each other. Altead SOPC-Builder does provide a Mutex on the Avalon bus for that purpose. I suppose it can issue an interrupt so that one CPU can notify the other of changes of the mailbox state.[/b] --- Quote End --- The mutex on the Avalon bus is automatically generated, isn't it? Which means although I cannot visually see it ,but the Avalon bus has its own arbitration, to prevent the conflict? I have already tested an idea. cpu_1 in charges of Program which stores in sdram ( reset addr 2) cpu_0 in charges of Uclinux which stores in sdram (reset addr 1) put the flag (or called it a status 32-bit storage ) in a on-chip memory (NO_DATA,DATA_IN,DATA_OUT) put the shared memory,which is used to store message, in a sram Program keep checking the status( on-chip mem ) ( I have already put a delay() function into it ) Uclinux writes a message onto shared memory and changes the flag, once program realize while checking, it will receive message from sram. However, when running the two processor simultaneously, cpu_1 keeps checking, cpu_0 runs uclinux, sometimes one or both of them go to dead. I don't know the reason why. Is it because they are using the same sdram for running? - Altera_Forum
Sorry, but I'm not inclined to act as a tutor on the basics of hardware and software design and of English language. :(
<div class='quotetop'>QUOTE (mschnell @ Aug 12 2009, 04:20 AM) <{post_snapback}> (index.php?act=findpost&pid=23489)</div>
--- Quote Start --- Sorry, but I'm not inclined to act as a tutor on the basics of hardware and software design and of English language. :( -Michael[/b] --- Quote End --- Sorry to bother you so much. But thank you anyway for your great patience. - Altera_Forum
So please come back after you did some decent research yourself. -Michael
<div class='quotetop'>QUOTE (mschnell @ Aug 12 2009, 08:26 AM) <{post_snapback}> (index.php?act=findpost&pid=23492)</div>
--- Quote Start --- So please come back after you did some decent research yourself. -Michael[/b] --- Quote End --- Thank you. I have tried dual core running simultaneously recently. However,I found that when running a uclinux system and a program generated on the basic of reference design "helloworld_small", it runs perfectly. When running a uclinux system and a program generated on the basic of reference design "helloworld", either of the process will stop. There's only a difference lies in the syslib between "helloworld_small" and "helloworld", I don't know why "helloworld" leading to the unknown interruption. - Altera_Forum
<div class='quotetop'>QUOTE (babysnow @ Aug 13 2009, 05:53 AM) <{post_snapback}> (index.php?act=findpost&pid=23499)</div>
--- Quote Start --- <div class='quotetop'>QUOTE (mschnell @ Aug 12 2009, 08:26 AM) <{post_snapback}> (index.php?act=findpost&pid=23492) --- Quote End --- --- Quote Start --- So please come back after you did some decent research yourself. -Michael[/b] --- Quote End --- Thank you. I have tried dual core running simultaneously recently. However,I found that when running a uclinux system and a program generated on the basic of reference design "helloworld_small", it runs perfectly. When running a uclinux system and a program generated on the basic of reference design "helloworld", either of the process will stop. There's only a difference lies in the syslib between "helloworld_small" and "helloworld", I don't know why "helloworld" leading to the unknown interruption. [/b] --- Quote End --- Now I can finished the program simply by the supply of helloworld_small reference design. And it's only 17kb size for elf file. Thank you anyway!
