16 years ago
How to read and write value in two different systems?
Dear everyone,
I am now working on a multicore system.
cpu_0 runs uclinux,
cpu_1 runs a piece of program,
the base address of led_red( pio ) in the SOPCBuilder is 0x00400000,
the base address of led_red in nios2_system.h in uclinux is 0x80400000.
I have succeed in writing a value onto the led_red through program in uclinux,
however, when I tried to read the written value through a program( cpu_1 ) without a system,
it always appears the same value "-1".
Here's the small program in cpu_0(uclinux).# define LEDR_BASE 0x80400000
int main(){
int *led_red = (int *) LEDR_BASE;
*(led_red) = 128;
return 0;
after running it in the uclinux, the 8th led_red lights on.
Here&#39;s the small program in cpu_1.# include <stdio.h># define LEDR_BASE 0x00400000
int main()
printf("Hello from Nios II!\n");
int *red_red = (int *)LEDR_BASE;
printf("%d",*red_red);
return 0;
after running it the console always shows the value of -1
I don&#39;t know why,could somebody help me?
Yours sincerely,
babysnow
    If you really want to do a shared memory region, you don&#39;t need the "flag", but you do need a hardware Mutex to allow the processors to be sure which one is allowed to write to critical memory locations e.g. to create a Mailbox mechanism: a CPU sets a bit to say: "mailbox contains data", the other CPU clears the bit to say: "data read and can be replaced" by new data. These operations need to be protected against each other. Altead SOPC-Builder does provide a Mutex on the Avalon bus for that purpose. I suppose it can issue an interrupt so that one CPU can notify the other of changes of the mailbox state.
    If the shared memory is a "hardware" unit dedicated for communication, this will not slow down the CPUs, as (AFAIK) the Avalon "bus" is not a real bus, but a link between any master and any slave is created, so that accesses from two masters to different slaves can be done in parallel .
    -Michael
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    but you do need a hardware Mutex to allow the processors to be sure which one is allowed to write to critical memory locations e.g. to create a Mailbox mechanism: a CPU sets a bit to say: "mailbox contains data", the other CPU clears the bit to say: "data read and can be replaced" by new data.[/b]
    --- Quote End ---
    What is the exact meaning of CPU bit?
    --- Quote Start ---
    These operations need to be protected against each other. Altead SOPC-Builder does provide a Mutex on the Avalon bus for that purpose. I suppose it can issue an interrupt so that one CPU can notify the other of changes of the mailbox state.[/b]
    --- Quote End ---
    The mutex on the Avalon bus is automatically generated, isn&#39;t it? Which means although I cannot visually see it ,but the Avalon bus has its own arbitration, to prevent the conflict?
    I have already tested an idea.
    cpu_1 in charges of Program which stores in sdram ( reset addr 2)
    cpu_0 in charges of Uclinux which stores in sdram (reset addr 1)
    put the flag (or called it a status 32-bit storage ) in a on-chip memory (NO_DATA,DATA_IN,DATA_OUT)
    put the shared memory,which is used to store message, in a sram
    Program keep checking the status( on-chip mem ) ( I have already put a delay() function into it )
    Uclinux writes a message onto shared memory and changes the flag, once program realize while checking, it will receive message from sram.
    However, when running the two processor simultaneously, cpu_1 keeps checking, cpu_0 runs uclinux, sometimes one or both of them go to dead.
    I don&#39;t know the reason why. Is it because they are using the same sdram for running?
    Sorry, but I&#39;m not inclined to act as a tutor on the basics of hardware and software design and of English language. :(
    -Michael
    <div class='quotetop'>QUOTE (mschnell @ Aug 12 2009, 04:20 AM) <{post_snapback}> (index.php?act=findpost&pid=23489)</div>
    --- Quote Start ---
    -Michael[/b]
    --- Quote End ---
    Sorry to bother you so much.
    But thank you anyway for your great patience.
    So please come back after you did some decent research yourself. -Michael
    <div class='quotetop'>QUOTE (mschnell @ Aug 12 2009, 08:26 AM) <{post_snapback}> (index.php?act=findpost&pid=23492)</div>
    --- Quote Start ---
    So please come back after you did some decent research yourself. -Michael[/b]
    --- Quote End ---
    Thank you.
    I have tried dual core running simultaneously recently.
    However,I found that when running a uclinux system and a program generated on the basic of reference design "helloworld_small", it runs perfectly.
    When running a uclinux system and a program generated on the basic of reference design "helloworld", either of the process will stop.
    There&#39;s only a difference lies in the syslib between "helloworld_small" and "helloworld", I don&#39;t know why "helloworld" leading to the unknown interruption.
    <div class='quotetop'>QUOTE (babysnow @ Aug 13 2009, 05:53 AM) <{post_snapback}> (index.php?act=findpost&pid=23499)</div>
    --- Quote Start ---
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    Thank you.
    [/b]
    --- Quote End ---
    Now I can finished the program simply by the supply of helloworld_small reference design.
    And it&#39;s only 17kb size for elf file. Thank you anyway!
