14 years agoHow to provide different clock for PHY Device
My board DE2-115 My PHY Device:88E1111 My project is about simple socket server.Now I can send words or command via Telnet or Ping, when I use a router(100Mbps). But, when I directly connec...
14 years ago --- Quote Start --- DO NOT TOUCH CONTENTS OF THAT FILE. Usually, it is already read-only. You have to generate 125MHz Yourself and supply that clock to the mii/gmii mux core. It's simple to read comments and undestand how it work. Do that instead of asking in forum. Ask here things that You can't get running, but not things, that You don't understand. --- Quote End --- In Ethernet RX PLL, the inclk--enet_rx_clk is 125MHz, the outclk--c2(enet_tx_clk_phy) is also 125MHz. And enet_tx_clk_phy is the outclock of ddr_o phy_ckgen .As follows: *************************************** ddr_o phy_ckgen ( .datain_h(1'b1), .datain_l(1'b0), .outclock(enet_tx_clk_phy), .dataout(enet_gtx_clk) ); // Ethernet RX PLL enet_rx_clk_pll enet_rx_clk_pll ( .inclk0(enet_rx_clk), .c0(enet_rx_clk_270deg), .c1(enet_tx_clk_mac), .c2(enet_tx_clk_phy) ); **************************************** I was really confused why 1000Mbps isn't work.
