15 years agohow to program/download NIOS II program by using an external processor?
Hi, everyone. I am trying to use an external processor (arm processor) to update configuration and NIOS II software program of the Cyclone III FPGA. After some search on the altera support...
15 years agoHi, dsl. Thanks for your reply.
I still have some questions about the usage of Avalon MM master and the implementation method. --- Quote Start --- You need to write an Avalon MM master that is connected external pins and use that to write to the memory. --- Quote End --- Does "the memory" include all of the following memory: FPGA Flash, FPGA EPCS, FPGA off-chip SRAM/SDRAM, and FPGA on-chip RAM? Could I only define a private interface/protocol to communicate with an Avalon MM master? Could I use the the JTAG interface to download/programme NIOS II software program just like the nios2 command tools does? If using JTAG is possible, Could you point some related documentations out to me? Thanks. htbegin
