10 years agoHow to program a new file into EPCS by erasing the old one.
Hello! I am using Quartus 10.1 and am trying to execute a LED blink program from nios. Target device is Cyclone II. I had successfully programmed the EPCS16 so that the LED blinks automatically after...
10 years agoYou can tell the Nios FLASH programmer tool to 'Ignore mismatched system ID' and 'Ignore mismatch system timestamp'. If you are 'Converting Programming File' via Quartus you can select 'Disable EPCS/EPCQ Id check' from the Advanced menu.
Happy New Year, Alex
