20 years ago
How to porting u-boot to my own board?
Hello, everyone
I want to use u-boot on my board. I have two questions.
1. Before I use u-boot on my board, I just try to compile u-boot first. So, I follow the readme file.
I use
make PK1C20_config
make all
But there have errors.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
In file included from /usr/include/sys/unistd.h:9,
from /usr/include/unistd.h:6,
from img2srec.c:61:
/usr/include/sys/types.h:106: conflicting types for `int8_t&#39;
/usr/include/stdint.h:38: previous declaration of `int8_t&#39;
/usr/include/sys/types.h:108: warning: redefinition of `int16_t&#39;
/usr/include/stdint.h:39: warning: `int16_t&#39; previously declared here
/usr/include/sys/types.h:110: warning: redefinition of `int32_t&#39;
/usr/include/stdint.h:40: warning: `int32_t&#39; previously declared here
/usr/include/sys/types.h:112: warning: redefinition of `int64_t&#39;
/usr/include/stdint.h:45: warning: `int64_t&#39; previously declared here
make[1]: *** Error 1
make[1]: Leaving directory `/cygdrive/d/My_Project/MtxCyclone_uBoot/BootLoader/u-boot-1.1.3/tools
make: *** [tools] Error 2[/b]
--- Quote End ---
I search the forum and find the answer given by smcnutt.
--- Quote Start ---
This looks like the sources directly from sourceforge.net ... this tree assumes you
have an appropriately configured native gcc and shell environment -- which
doesn&#39;t come with the nios2 toolchain 8-P The easiest thing to do is get the source
tree from http://www.pysent.com/download (http://www.pysent.com/download) -- this tree has certain "nips & tucks"
made to build cleanly with the default nios2 toolchain (under cygwin) -- and it&#39;s
more up-to-date than the sourceforge tree (WRT Nios-II, the sourceforge tree
has been lagging by several months).[/b]
--- Quote End ---
But I can not access the web link. Can give me the right link or the files?
2. If I want use u-boot on my MtxCyclone Board, how can I do?
Just what should I do according to the PK1C20.h?
Can give me more information or detailed steps than readme file?
Thank you very much,
LiangYi
    Hi Scott,
    I search the files related with flash in u-boot directory and find some
    > ..\u-boot\common\cmd_flash.c
    > ..\u-boot\common\env_dataflash.c
    > ..\u-boot\common\env_flash.c
    > ..\u-boot\common\flash.c
    > ..\u-boot\drivers\cfi_flash.c
    > ..\u-boot\include\flash.h
    > ..\u-boot\include\dataflash.h
    > ..\u-boot\board\altera\common\flash.c
    > ..\u-boot\board\altera\dk1c20\flash.c
    > ..\u-boot\board\altera\common\AMDLV065D.c
    > ..\u-boot\board\psyent\common\AMDLV065D.c
    > .. and the cfi_flash.c you send to me
    I have found that all *.c files are based on flash.h, what the relationship between these files?
    I know the function below, they are flash driver for u-boot.
    But, the files below play what function. Do they have relation with u-boot flash driver?
    LiangYi
    Hi LiangYi,
    This implements all of the flash commands (e.g.: erase, protect, etc.)
    Used for storing non-volatile environment.
    Implements some higher-level flash routines.
    Low-level CFI flash driver implementation. This can be used rather than implementing your own flash
    driver in your board-specific source tree. Many boards have their own "flash.c" file that is customized
    for the specific flash device on the board.
    But don&#39;t take my word ... the best way to understand how things work is to read through the code
    yourself ;-) Start with the following:
    common/cmd_flash.c -- start with do_flerase().
    common/cmd_mem.c -- start with do_mem_cp().
    It should all become clear.
    --Scott
    Hi Scott,
    > Until you can successfully write your environment to flash you will get the warning message.
    Also, I tried the cfi_flash.c that I sent you on two different boards (EP1C20 and PCI-5441) and
    it works ok for me. However, both boards use 8-bit devices and do not implement data cache.
    If you have a data cache, I don&#39;t think cfi_flash.c will work -- it&#39;s currently not coded to use
    the ld/st io instructions.
    Thank for your remind. I use nios/f core before, so when I change to nios/s core. My flash seems to work.
    I download uImage(kernel) to my flash(offset=0x0) and run
    ==>bootm 0, my kernel is booted.
    --- Quote Start ---
    ==> bootm 0
    # # Booting image at 00000000 ...
    ?nbsp; Image Name:?nbsp; Mtx uClinux 1.4
    ?nbsp; Image Type:?nbsp; Nios-II Linux Kernel Image (gzip compressed)
    ?nbsp; Data Size:??753694 Bytes = 736 kB
    ?nbsp; Load Address: 01000000
    ?nbsp; Entry Point:?01000000
    ?nbsp; Verifying Checksum ... OK
    ?nbsp; Uncompressing Kernel Image ... OK
    Linux version 2.6.11-uc0 (LiangYi@liangyi) (gcc version 3.4.1 (Altera Nios II 5.0 b73))# 1 Fri Sep 30 00:36:27 2005
    uClinux/Nios II
    Altera Nios II support ?2004 Microtronix Datacom Ltd.
    setup_arch: No persistant network settings signature at 003F0000
    Built 1 zonelists
    Kernel command line: root=/dev/mtdblock0 ro
    PID hash table entries: 64 (order: 6, 1024 bytes)
    Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
    Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Memory available: 6352k/8192k RAM, 0k/0k ROM (1426k kernel code, 295k data)
    Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    NET: Registered protocol family 16
    NIOS serial driver version 0.0
    ttyS0 (irq = 2) is a builtin NIOS UART
    Serial: JTAG UART driver $Revision: 1.4 $
    ttyJ0 at MMIO 0x80800800 (irq = 1) is a jtag_uart
    io scheduler noop registered
    io scheduler anticipatory registered
    io scheduler deadline registered
    io scheduler cfq registered
    RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
    eth0: Open Ethernet Core Version 1.0
    ?oeth_probe: 65536 Khz Nios: 16 RX, 16 TX buffs
    ???????NO Custom HW ALIGN.
    ???????CONFIG_NIOS2_HW_MULX??defined.
    ???????CONFIG_NIOS2_HW_MUL_OFF NOT defined.
    Microtronix map: Found 1 x16 devices at 0x0 in 16-bit bank
    Amd/Fujitsu Extended Query Table at 0x0040
    number of CFI chips: 1
    cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
    cmdlinepart partition parsing not available
    RedBoot partition parsing not available
    Using Microtronix development partition definition
    Creating 2 MTD partitions on "Microtronix map":
    0x00200000-0x00800000 : "romfs"
    mtd: partition "romfs" extends beyond the end of device "Microtronix map" -- size truncated to 0x200000
    0x00000000-0x00200000 : "loader/kernel"
    NET: Registered protocol family 2
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP established hash table entries: 512 (order: 0, 4096 bytes)
    TCP bind hash table entries: 512 (order: -1, 2048 bytes)
    TCP: Hash tables configured (established 512 bind 512)
    NET: Registered protocol family 17
    Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)[/b]
    --- Quote End ---
    I can not load filesystem. I first build filesystem project in Nios IDE, then I gzip the romfs.bin > romfs.bin.gz.
    I download romfs.bin.gz to flash at offset=0x200000.
    Right? How you do it?
    I have run Mtx uClinux ok in my board under Nios IDE(Directly upload .bin to board).
    Misfortune, the board I use is borrowed from other people. I have to return it today.
    Thank you all the same.
    LiangYi
    Hi LiangYi,
    Good -- from a u-boot point-of-view, we&#39;re done ;-)
    Ok ... but this is not a u-boot issue. You should probably start a new topic so people who are not interested in u-boot will contribute.
    --Scott
    To LiangYi,
    --- Quote Start ---
    0x00000000-0x00200000 : "loader/kernel"[/b]
    --- Quote End ---
    Your mtd partition definition has a little error.
    Seconed, Could you not zip "romfs.bin" first, just upload to flash with original "romfs.bin"?
    However, I&#39;d like to know/discuss how to implement the zipped "romfs.bin" to reduce flash capicity.
