21 years agoHow to porting u-boot to my own board?
Hello, everyone I want to use u-boot on my board. I have two questions. 1. Before I use u-boot on my board, I just try to compile u-boot first. So, I follow the readme file. I use ...
20 years agoHi Scott,
>>> I see a text in PK1C20.h. <div class='quotetop'>QUOTE </div> --- Quote Start --- /*------------------------------------------------------------------------ * EPCS Device -- wne CFG_NIOS_EPCSBASE is defined code/commands for * epcs device access is enabled. The base address is the epcs * _register_ base address, NOT THE ADDRESS OF THE MEMORY BLOCK. * The register base is currently at offset 0x600 from the memory base. *----------------------------------------------------------------------*/# define CFG_NIOS_EPCSBASE 0x02100200 /* EPCS register base */[/b] --- Quote End --- I look the epcs controller data sheet, its registers map is 0x000 . Boot ROM Memory 0x0FF 0x100 Read Data 0x101 Write Data 0x102 Status 0x103 Control 0x104 Reserved 0x105 Slave Enable 0x106 End of Packet Why the text says <div class='quotetop'>QUOTE </div> --- Quote Start --- "The register base is currently at offset 0x600 from the memory base."[/b] --- Quote End --- I try to set offset=0x110,# define CFG_NIOS_EPCSBASE 0x00400110(my epcs base=0x00400000). When run ==>epcs info, it display <div class='quotetop'>QUOTE </div> --- Quote Start --- ==> epcs info epcs: device not found. ==>[/b] --- Quote End --- Why, I have avoided the epcs registers address! I retry offset=0x200, it runs OK. Another, 0x000 . Boot ROM Memory 0x0FF Does here store the boot_loader_epcs.srec? And the boot_loader_epcs.srec runs in FPGA on-chip-rom? I do not know it clearly, and altera's document do not describe this. >>> <div class='quotetop'>QUOTE </div> --- Quote Start --- > Am29DL323GB Flash: 4M, base address:=0x00000000. Is your base address correct? The base address for your flash was 0x0020_0000 in the last email you sent.[/b] --- Quote End --- Yes, my flash base is 0x0. >>> <div class='quotetop'>QUOTE </div> --- Quote Start --- > *** Warning - bad CRC, using default environment -#define CFG_ENV_ADDR (CFG_RESET_ADDR + CFG_MONITOR_LEN) +#define CFG_ENV_ADDR CFG_FLASH_BASE /* Or whatever you like */[/b] --- Quote End --- I change as you say, but have no effect on u-boot boot-up message. >>> I think the sequence of u-boot running in epcs4 is: First, the FPGA is configured with config data in epcs. Then, boot_loader_epcs.srec stored in epcs runs in FPGA on-chip rom and copy u-boot to the u-boot TEXT_BASE(elf link address). Finally, u-boot runs in TEXT_BASE, initial hardware and generate the environment(heap, global data, stack). Right? Thank you, LiangYi
