15 years agohow to modify preprocessor options in NIOS II?
I am new to Altera NIOS II. I need to add DALT_USE_LCD_16207 to preprocessor option to enable LCD controller while using reduced device for other components. But I could not find where for me to modify preprocessor option. Any help will be appreciated!
I am using NIOS II v9.1 sp2. Thanks...3 Replies
Did you ever figure this out, I am in a similar situation.
Thanks, John - Altera_Forum
how about
Properties (of the Syslib or Project) C/C++ Build NIOS II Compiler Preprocessor Define Symbols - Altera_Forum
Thanks for the Response Karsten. Just to avoid confusion if someone else runs across this, in 9.1sp2 the definition can be added at:
Properties NIOS II BSP Properties Defined Symbols
