16 years agoHow to manage two Ethernet MACs?
Hi I need to implementent a system with 2 Ethernet MAC on a Cyclone III devboard. The two MAC must work in different ways: - eth1 : use the iNiche stack and connects to my client application -...
10 years ago --- Quote Start --- I eventually solved the above problem. If anyone has a similar issue, I can give a few hints. --- Quote End --- Hi, Were you ale to use the TSE IP core for Ethercat master? How is the performance?
