16 years agoHow to manage two Ethernet MACs?
Hi I need to implementent a system with 2 Ethernet MAC on a Cyclone III devboard. The two MAC must work in different ways: - eth1 : use the iNiche stack and connects to my client application -...
13 years agoHello Seilaser
--- Quote Start --- I eventually solved the above problem. If anyone has a similar issue, I can give a few hints. --- Quote End --- I need to use EtherCAT interface in DE2-115, am new to this. Am little confused between EtherCAT and Ethernet MACs. Can you refer me some examples of EtherCAT implementation which will be very helpful. thanks, vrv.
