16 years agoHow to make sure nios send a single cycle control signal to peripheral?
hye everyone..this is a very basic question i was testing how to control custom HW using nios. The custom HW in my case is just a simple counter. ive attach my counter to avalon bus and ma...
16 years agoYou specify yourself the number of wait cycles when you create the component in SOPC builder. With the default values, a read signal is active during two cycles and a write signal during one cycle, so your code should be fine and you don't need to detect an edge on the avalon control signals.
For your second question, I don't know. I stopped trying to understand how the CPU does the 8-bit accesses and just do everything with 32-bit data busses. It saves a lot of trouble ;) I think that the CPU is trying to do an 8-bit access but the switching fabric divides it in 4 8-bit accesses, but I'm not sure.
