19 years ago
How to make custom target board?
hi,I'm creating my own target board with the board discription editor.I use quartus2, version 5.1,and Nios2 version 5.1.it seems that mk_target_board can't be used.I just declared the flash memory on the board,and sepcified the regions,but it doesn't work,with the flash memory problems.what else should I do if I want to make my custom target board?I've read the flash programmer and SOPC Builder handbook,but the answer is not be found.
    Thank you.I've resolved this problem and the LED works.I checked the pin assignment,and found a mistake.I use Quartus 4.2,and feel that mk_target_board is better than board description editor.
    you will have problems with the flash programmer, since it was changed in version 5.1
    IzI
