How to load data to FPGA memory using NIOS application?
Hi Yogesh,
You can find the documentation on the following link [1], next you need to find the SDRAM test in Nios ll.
Once you open the .par, you need to follow the steps and compile on eclipse, then at your project folder you are going to find a software folder, you can find the C code there.
Best regards.
Isaac
- Yogesh6 years ago
Hi Isaac,
I dont have the DE -10 lite board to exceute the example design provided by you.
I am working with cyclone V GT board . That is why I want to understand the concept/ C code which writes the data to memory of FPGA. So that I can replicate the same in my C application.
I downloaded .par file and opened it in quartus . I could not find the software folder which contains the c codes required for eclipse. I have attached the screeshot of the files that are generated.
Please have a look into it and provide me the c code for the same
regards,
Yogesh
