Yogesh
6 years agoHow to load data to FPGA memory using NIOS application?
Hi, I have developed some NIOS application, and I am using NIOS II Eclipse tool to run the same. Suppose I have some data in files. I want to load some amount of locations in DDR of my FPGA device wi...
Isaac_V_Intel
Contributor
6 years agoHello Yogesh,
You actually choose between debug or run mode on your toolbar.
Here is an example of a DRAM test on the following link [1], you are going to find the documentation at the same link. Next you are going to download the .par and create a project starting with this. This test is proved in Max 10 board.
[1] https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/sdram-nios-test-max10-de10-lite/
Isaac Vazquez.
Yogesh
6 years agoHi Isaac,
The documentation link is not reachable.I am not able to access it.
And I did download the project , But I couldnt find the C codes to run on eclipse?
Am I missing something ?Please guide me.
regards,
Yogesh
