16 years agoHow to import an image to Nios II as an array?
Hi, Does anyone know how to convert any type of image into a c array which can be read by using the gimp bmp library in the Nios II IDE 9.0? Yours, Hany Assasa
16 years agoSomething like the following will generate a data item initialised with the bytes from a file - which might do what you want:
objcopy -I binary -O elf32-little -B nios2
--rename-section .data=.rodata,alloc,load,readonly,data,contents
image.bmp image.o
