10 years agoHow to implement an NoC (Network on Chip) in my DE1-SOC (Nios-II, Qsys)?
I was wondering if it's possible to implement a simple Network-on-Chip with for example, 100 Cores, connected with routers in a torus network? What resources of my DE1-SOC can I use for this? Nios-II...
10 years ago100 cores of what?
Nios relies on the Avalon Bus - usually with the Nios acting as the master and other units connected via a memory mapped avalon interface. This way you can have any existing IP or any other IP you chose to design yourself (as avalon is a straight forward interface, very similar to AXI). NoC is usually a term used for Asic, not FPGA.
