11 years agoHow to get bare metal app running independently on SoCkit?
Hello all, I have a simple "hello world" bare metal app running in Debug using DS-5 (Eclipse) Altera Edition. Target system is Altera/Arrow SoCkit with Cyclone V. My problem is how to get this runn...
10 years ago --- Quote Start --- There is actually a good example in the "Hello World" example at this link: http://www.alterawiki.com/wiki/socbootfromfpga It really all depends what you mean by "bare metal". You can probably get your code running in the On-Chip Memory by replacing the preloader with your own code and placing your code in the 0xA2 partition, but you'll have to do any chip initialization yourself. I haven't seen any good examples yet on working with no preloader, even though there is no particular reason why you couldn't. You could even build an RTOS in DS-5 and port it over, if you wanted to try that. --- Quote End --- But this example of fpga only power up the preloader from the FGPA memory, there rest of the files looks like still remain it in the SD card.
