16 years agoHow to enable/disable NicheStack features ?
I'm a beginner to NicheStack and networking. Going through some documentation and code, now I know that NicheStack features can be controlled by modifying# defines in ipport.h file. But is there any documentation stating which flags should be enabled for particular feature ? For example for full DHCP support, define DHCP_SERVER and DHCP_CLIENT. Thanks, Sanjay5 Replies
Hi SanjayJ
I'm a beginner too and looking for the same documentation. Did you find some? Thank you brunjak - Altera_Forum
Hi brunjak,
Unfortunately I did not. However, I might be able to help you in case you are looking for the thing which I am aware of. :-) -Sanjay - Altera_Forum
Hi SanjayJ
Thank you for your fast response. I only thought it would be nice to have some documentation. Until now I can work with the configuration which is done in the simple socket server application. Thank you Regards brunjak - Altera_Forum
I would start with the NIOS Eclipse IDE
Open the system library properties of your project. Then press "Software Components ..." Select the Niche Stack and set the options as you need them. - Altera_Forum
Browse the Altera directories for the file named Nichestack_Ref.zip. In my installation I find it in: c:\altera\90sp2\nios2eds\components\altera_iniche\UCOSII\31src\doc31.zip Regards
