14 years agoHow to disable RTOS?
Hi! Our Company is developing soft-processors using Nios I, but due to Nios I is not supported any more, as well as due to more advantageous JTAG use, we have to use Nios II. The problem we are ...
14 years agoHi Artyom,
you can also take a look to objdump file (clearly previously enabled to be generated) just to understand what still remain in your application. Moreover you have also to remember that, all peripheral that you've foreseen in your FPGA design, automatically at compilation of BSP includes proper device driver: therefore if you don't want to use them you have to remove from you design or remove device driver within BSP editor. Ciao
