12 years ago
How to design a Tristate Controller
Hi all,
During the design of ethernet using EP4CE30 , I need to design a custom tristate controller which contains a avalon MM master and a tristate conduit master . The tristate conduit master will connect to a tristate conduit pin sharer. I want to get a example of tristate controller contain both avalon MM master and tristate conduit master.Can anyone help me?
I also design a module as follow , bu t the name cannot be recognized by the tristate conduit master in qsys, and can not be seen in the tristate conduit pin sharer. why?
// sram_m.v
// This file was auto-generated as a prototype implementation of a module
// created in component editor. It ties off all outputs to ground and
// ignores all inputs. It needs to be edited to make it do something
// useful.
// This file will not be automatically regenerated. You should check it in
// to your version control system if you want to keep it.
module sram_m (
input wire clk, // clock.clk
input wire reset, // reset.reset
//s0 interface
input wire [20:0] s0_addr, // s0.address
input wire s0_rdn, // .read
input wire s0_oen, //output
input wire s0_cen, //chipselect
output wire [15:0] s0_rdata, // .readdata
input wire s0_wrn, // .write
input wire [31:0] s0_wdata, // .writedata
input wire [1:0] s0_byten, //byteenable
// tcm interface
output wire [20:0] tcm0_address_out, // tcm0.addr
output wire [15:0] tcm0_data_out, // tcm0.wdata
input wire [15:0] tcm0_data_in, // tcm0.wdata
output wire tcm0_chipselect_n_out, // tcm0.cen
output wire tcm0_write_n_out, // tcm0.wrn
output wire tcm0_read_n_out, // tcm0.rdn
output wire [1:0] tcm0_byteenable_n_out, //byteenable
output wire tcm0_data_outen,
input wire tcm0_grant, // tcm0.grant
output wire tcm0_request // .request
// TODO: Auto-generated HDL template
assign s0_rdata = ((tcm0_grant==1) && (s0_rdn==0))? tcm0_data_in : 16'hzzzz;
// assign tcm0_addr_out = (tcm0_grant==1 )? s0_addr : 16'hzzzz;
// assign tcm0_wdata_out = ((tcm0_grant==1)&& ( s0_wrn ==0))? s0_wdata : 16'hzzzz;
// assign tcm0_data_outen = ((tcm0_grant==1)&& ( s0_wrn ==0))? 1'b1 : 1'b0;
// assign tcm0_cen_out = ((tcm0_grant==1))? s0_cen : 1'bz;
// assign tcm0_request = s0_cen ? 1'b0 : 1'b1;
endmodule
