15 years agoHow to design a component which has N number of Avalon ST Sink ports in SOPC Builder
Hi, I need to design a component which has N number of Avalon ST Sink interfaces. The number of Avalon ST interfaces required is user programmable. It should be generic. For Example, ho...
15 years agoYou're quite right that handling 512 connections graphically would be a chore, but then it was an academic question ...
But I have a few building blocks with either multiple sinks or multiple source and I have one with multiple sinks and sources. This means if I want to keep things tidy I have to write variations on a as needed basis, or try the .tcl way. I'm not fond of having to write a .tcl script because somebody else flawed the design (aside from the time spent to learn the quirks). And I have already seen too many .tcl scripts calling another .tcl script calling ... , you get the idea. I didn't see how this setting the inputs (what about unused outputs?) to a default value is done in the example I studied, but again I'm not an a .Tcl expert nor do I read much Verilog. I'm pretty sure that a lot of 'unnecessary' info and warning messages will be generated. I can live with the Info messages (I generate some myself), but I always get worried about Warning messages, as an old saying goes: "a warning is an error waiting to happen" (this goes back to the early days of C-programming). Can you explain why generics don't work, or what the rationale is behind leaving them out is?
