15 years agohow to create a user interface using nios ii , rs232 of DE2 board
hello , i'm working on a student project using the nios ii processor and i need to build a user interface in a PC . i have the DE2 board. i'm a beginner with the nios ii and i really don't know to in...
15 years agoI mentioned Hyperterminal because this is what is available on Windows systems. You can use any program which can send and receive data to and from the serial port.
As I said above, you can even write your own terminal program: if you have minimal programming experience, you can write a simple one in less than a hour.
