15 years agoHow to comiple a single C file in Nios
When I right click a C file and choose "Build selected file(s)", an error message turned up which says "..Operation not enabled". https://sites.google.com/site/nswbanana/store_1/build_file.PNG?att...
15 years ago --- Quote Start --- Try going through one of the included examples and/or tutorials. You have to create a Nios II project, compile it, and then "Run" or "Debug" the result on a target board. In general, you can't do what you're asking to do unless you're already _running_ in the runtime environment that you'd like to compile for... i.e.: Compiling a program for Windows while running in Windows...same for Linux. Regards, slacker --- Quote End --- thanks for your answer. I think I haven't explained my question clearly. I do have a working project. I just want to compile a single C file in the project.
