15 years agoHow to call tightly couple module during C code for NIOS II
Hi there... I am a new to NIOS II technology and I would like to ask... how can we call for module in C programming for NIOS II. Because from my understanding, we can add some module that coupled wit...
15 years agoThank you gaudetteje for the sample code. Looking at your code, I realized I made a mistake with the direction of the inpt/ouput ports. But I am still facing problems compiling. So let's start fault finding.
- I have 3 PIOs in SOPC Builder. 2 out (data_out_0 and data_out_1) and 1 in (result_in0) - Then in my main.v file port declaration, I put
input result_data;
output int_data_line0;
output int_data_line1;
- In the SOPC generated NIOS system, I put
nios_system NiosII (
// my pios
.in_port_to_the_result_in0 (result_data),
.out_port_from_the_data_out0 (int_data_line0),
.out_port_from_the_data_out1 (int_data_line1),
-Finally I instantiate my custom verilog module
add_two two_vals(
.clk(system_clock),
.line_1_in (int_data_line0),
.line_2_in (int_data_line1),
.result_back_out(result_data),
When I compile this, I get Error : Net "result_data",which fans out to "nios_system:NiosII|in_port_to_the_result_in0[0]", cannot be assigned to more than one value. Could this error be due to a badly written add_two.v module? I still have the module as before except I add tried to add a clock to it :
module add_two (
// Inputs
clk,
line_1_in,
line_2_in,
// Output
result_back_out
//Port Declarations
// Inputs
input clk;
input line_1_in; // 8 bit value
input line_2_in;
// Output
output wire result_back_out; // assume 8 bit
reg original_line_1;
reg original_line_2;
reg temp_sum;
always@ (posedge clk)
begin
original_line_1 <= line_1_in;
original_line_2 <= line_2_in;
temp_sum <= original_line_1 + original_line_2;
end
assign result_back_out = temp_sum ;
endmodule
I also saw a warning message in SOPC builder for that PIO In when I generated the system which said: 'PIO Inputs are not hardwired in test bench. Undefined values will be read from PIO inputs during simulation.'. Am I doing something wrong there too?
