15 years agoHow to call tightly couple module during C code for NIOS II
Hi there... I am a new to NIOS II technology and I would like to ask... how can we call for module in C programming for NIOS II. Because from my understanding, we can add some module that coupled wit...
15 years agoThere are multiple ways to do this depending upon your HDL module. You can include your own module as a custom instruction in the SOPC Builder, as you've suggested. A simpler method would be to interface with the PIO ports. This would require instantiating your module in the high-level HDL file in Quartus, then connect your Nios2 PIO ports to your module.
For example, if you have a Verilog module that outputs a single number as a result of two inputs, simply generate 3 PIOs in your SOPC builder and connect. Your Nios program would write a number to each output PIO, then read from the input PIO after a minimum timing requirement. On the other hand, if your module requires a large amount of data stored in SDRAM (i.e. computing an md5 hash), then using the PIOs might not be such a good idea since they won't have access to the Avalon-MM bus. A 3rd method would be to create your own Avalon-MM component, which would require the most amount of programming. For what it's worth, I haven't had a good experience using Custom Instructions on anything a PIO interface couldn't easily handle. -J
