20 years ago
how to build toolchain on linux ,no internet
Dear ALL
beacuse i can't connect the Internet in my Linux computer. so i find many many error when i build the toolchain.
first i read the script of build ,i find
wget -N http://www.kernel.org/pub/linux/kernel/v2.....6.15.4.tar.bz2 (http://www.kernel.org/pub/linux/kernel/v2.6/linux-2.6.15.4.tar.bz2)
wget -N http://www.uclinux.org/pub/uclinux/uclinux...15-uc0.patch.gz (http://www.uclinux.org/pub/uclinux/uclinux-2.6.x/linux-2.6.15-uc0.patch.gz)
wget -N http://www.uclinux.org/pub/uclinux/dist/uc...0051209.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uclinux-dist-test-20051209.tar.bz2)
wget http://buildroot.uclibc.org/downloads/snap...0060207.tar.bz2 (http://buildroot.uclibc.org/downloads/snapshots/buildroot-20060207.tar.bz2) -O buildroot-snapshot.tar.bz2
wget http://www.uclibc.org/downloads/snapshots/...0060207.tar.bz2 (http://www.uclibc.org/downloads/snapshots/uclibc-20060207.tar.bz2) -O uClibc-snapshot.tar.bz2
wget http://busybox.net/downloads/snapshots/bus...0060207.tar.bz2 (http://busybox.net/downloads/snapshots/busybox-20060207.tar.bz2) -O busybox-snapshot.tar.bz2
so i dowload it in other computer. and then cp to the ~/download
but i think i shoud do it over .
but i find i must download a file
linux-libc-headers-2.6.11.0.tar.bz2
and then i copy it to ~/buildroot/dl
but i find the next error
* Target Options
* filesystem for target device
cramfs root filesystem (BR2_TARGET_ROOTFS_CRAMFS) [N/y/?] n
cloop root filesystem for the target device (BR2_TARGET_ROOTFS_CLOOP) [N/y/?] n
ext2 root filesystem (BR2_TARGET_ROOTFS_EXT2) [Y/n/?] y
size in blocks (leave at 0 for auto calculation) (BR2_TARGET_ROOTFS_EXT2_BLOCK
S) [0] 0
inodes (leave at 0 for auto calculation) (BR2_TARGET_ROOTFS_EXT2_INODES) [0] 0
reserved blocks (BR2_TARGET_ROOTFS_EXT2_RESBLKS) [0] 0
Make all files be owned by root (BR2_TARGET_ROOTFS_EXT2_SQUASH) [Y/n] y
Output File (BR2_TARGET_ROOTFS_EXT2_OUTPUT) [$(IMAGE).ext2] $(IMAGE).ext2
gzip the output file (BR2_TARGET_ROOTFS_EXT2_GZ) [N/y] n
also copy the image to... (BR2_TARGET_ROOTFS_EXT2_COPYTO) []
jffs2 root filesystem (BR2_TARGET_ROOTFS_JFFS2) [N/y/?] n
squashfs root filesystem (BR2_TARGET_ROOTFS_SQUASHFS) [N/y/?] n
tar the root filesystem (BR2_TARGET_ROOTFS_TAR) [N/y/?] n
* bootloader for target device
* Board Support Options
* Generic System Support
Generic wireless access point (BR2_TARGET_GENERIC_ACCESS_POINT) [N/y/?] n
Generic firewall (BR2_TARGET_GENERIC_FIREWALL) [N/y/?] n
Generic development system (BR2_TARGET_GENERIC_DEV_SYSTEM) [N/y/?] n
grep: /home/wyouken/buildroot/build_nios2/staging_dir/include/bits/uClibc_config
.h: 没有那个文件或目录
package/wipe/wipe.mk:19: warning: overriding commands for target `/home/wyouken/
buildroot/dl/'
package/mtd/mtd.mk:44: warning: ignoring old commands for target `/home/wyouken/
buildroot/dl/'
cp toolchain/uClibc/uClibc.config /home/wyouken/buildroot/toolchain_build_nios2/
uClibc/.config
/home/wyouken/buildroot/toolchain_build_nios2/bin/sed -i -e 's,^CROSS_COMPILER_P
REFIX=.*,CROSS_COMPILER_PREFIX="/home/wyouken/buildroot/build_nios2/staging_dir/
bin/nios2-linux-uclibc-",g'
-e 's,# TARGET_nios2 is not set,TARGET_nios2=y,g'
-e 's,^TARGET_ARCH="none",TARGET_ARCH=\"nios2\",g'
-e 's,^KERNEL_SOURCE=.*,KERNEL_SOURCE=\"/home/wyouken/buildroot/toolchai
n_build_nios2/linux\",g'
-e 's,^RUNTIME_PREFIX=.*,RUNTIME_PREFIX=\"/\",g'
-e 's,^DEVEL_PREFIX=.*,DEVEL_PREFIX=\"/usr/\",g'
-e 's,^SHARED_LIB_LOADER_PREFIX=.*,SHARED_LIB_LOADER_PREFIX=\"/lib\",g'
/home/wyouken/buildroot/toolchain_build_nios2/uClibc/.config
/home/wyouken/buildroot/toolchain_build_nios2/bin/sed -i -e 's,^.*UCLIBC_HAS_LFS
.*,UCLIBC_HAS_LFS=y,g' /home/wyouken/buildroot/toolchain_build_nios2/uClibc/.con
fig
/home/wyouken/buildroot/toolchain_build_nios2/bin/sed -i -e 's,.*UCLIBC_HAS_WCHA
R.*,UCLIBC_HAS_WCHAR=y,g' /home/wyouken/buildroot/toolchain_build_nios2/uClibc/.
config
/home/wyouken/buildroot/toolchain_build_nios2/bin/sed -i -e 's,# UCLIBC_HAS_THRE
ADS is not set,UCLIBC_HAS_THREADS=y,g' /home/wyouken/buildroot/toolchain_build_n
ios2/uClibc/.config
/home/wyouken/buildroot/toolchain_build_nios2/bin/sed -i -e 's,# PTHREADS_DEBUG_
SUPPORT is not set,PTHREADS_DEBUG_SUPPORT=y,g' /home/wyouken/buildroot/toolchain
/home/wyouken/buildroot/toolchain_build_nios2/bin/sed -i -e 's,# LINUXTHREADS_OL
D is not set,LINUXTHREADS_OLD=y,g' /home/wyouken/buildroot/toolchain_build_nios2
/uClibc/.config
mkdir -p /home/wyouken/buildroot/toolchain_build_nios2/uClibc_dev/usr/include
mkdir -p /home/wyouken/buildroot/toolchain_build_nios2/uClibc_dev/usr/lib
mkdir -p /home/wyouken/buildroot/toolchain_build_nios2/uClibc_dev/lib
make -C /home/wyouken/buildroot/toolchain_build_nios2/uClibc
PREFIX=/home/wyouken/buildroot/toolchain_build_nios2/uClibc_dev/
DEVEL_PREFIX=/usr/
RUNTIME_PREFIX=/home/wyouken/buildroot/toolchain_build_nios2/uClibc_dev/
HOSTCC="gcc"
pregen install_dev &&
touch /home/wyouken/buildroot/toolchain_build_nios2/uClibc/.configured
make[1]: /home/wyouken/buildroot/build_nios2/staging_dir/bin/nios2-linux-uclibc-
gcc: Command not found
make[1]: Entering directory `/home/wyouken/buildroot/toolchain_build_nios2/uClib
c'
BBmake -C extra/config conf
make[2]: /home/wyouken/buildroot/build_nios2/staging_dir/bin/nios2-linux-uclibc-
HB`?make[2]: /home/wyouken/buildroot/build_nios2/staging_dir/bin/nios2-linux-u
clibc-gcc: Command not found
?B?Bmake[2]: *** No rule to make target `|', needed by `../../extra/config/c
onf.o'. Stop.
make[1]: *** [extra/config/conf] Error 2
make[1]: Leaving directory `/home/wyouken/buildroot/toolchain_build_nios2/uClibc
make: *** [/home/wyouken/buildroot/toolchain_build_nios2/uClibc/.configured] Err
or 2
./build0207: line 57: cd: /home/wyouken/buildroot/build_nios2/staging_dir/includ
e/linux: 没有那个文件或目录
rm: lstat‘config.h’失败: 没有那个文件或目录
rm: lstat‘autoconf.h’失败: 没有那个文件或目录
i want to know how to it when i can't connect the internet . beacuse i think the script maybe download some improtant file .
help me !
    The init stopped?
    Try rebuild busybox.
    rm -rf ~/rootfs
    cd ~/buildroot
    rm -rf build_nios2/busybox
    make
    cp -a ~/buildroot/build_nios2/root ~/rootfs
    cd ~/rootfs#  remove include and lib to save space#  the dev nodes are generated via ~/download/rootfs_list
    rm -rf dev usr/include usr/lib#  you may use this instead of the one from buildroot
    cp ~/download/inittab etc
    cd ~/linux-2.6.x#  rebuild image for initramfs
    make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-
    Dear Hippo
    thank you very much ! i have success to run the Linux . you give more help !
    I wish we have more intercommunion. i will write a summary for how to build toolchain in chinese version .
    now , I have a EP2C35 (dev kit ALTERA ), so next I will test Ethernet and CF and IDE harddisk . I wish you can give me help . i will post the information , that i learn , to the forum .
    Thanks !
    I am location in shenzhen china .
    Sure, I will send my mail to you.
    But, first edit your previous post, remove your real e-mail address.
    It is likely to be cropped by spammer.
