How is Nios V's MHARTID csr register assigned a determined value?
- 1 year ago
Hi
The Quartus 24.1 Standard is expected to be release by early March 2025.
Jingyang, Teh
Hi
For the MHARTID, this could be set in the platfrom designer under the NiosV IP parameters shown below:
Jingyang, Teh
Thank you for your response.
I am using "Platform Designer 23.1 Build 991 (Quartus Prime Version 23.1std.0 991 11/28/2023 SC Standard Edition)" and these are the options available:
As you can see, there is no parameter for MHARTID.
Which Quartus Prime and Platform Designer versions should I install to allow modifying the MHARTID csr register?
Domingo
- Benitez__Domingo1 year ago
I would like to provide additional information. I need to use Quartus Prime Standard Edition because the FPGA device where I am configuring a Nios V/m processor is Cyclone IV. The latest version of Standard Edition for Windows is 23.1.1.
As described in the Nios® V Embedded Processor Design Handbook (Updated for Intel® Quartus® Prime Design Suite: 23.4, date: 2023.12.04), Figure 10 at page 20, the parameter for Nios V/m Microcontroller Intel FPGA IP named "CPU Architecture" has a single option: Enable Pipelining in CPU. The parameter for the MHARTID csr register is not included.
Then I think your previous answer is based on a Quartus Prime 24.x version.
Is that right?
Domingo.
