15 years agoHow fast(max frequency) can Nios run on DE2-70 board
I want to try some frequency higher than 100Mhz on DE2-70.
I built a simple system( only mcu, sysid, onchip-ram and jtag-uart) . But I cannot get it work with 105 ,116.6 or 120 Mhz, I even can not read the sysid. Is 100Mhz the fastest speed I can get?4 Replies
No, You can get even faster, but You need to add proper constraints for Your design.
I think someone has previously mentioned that the JTAG debug has to be run at a lower clock rate behind an appropriate bridge.
I'm not aware of an upper limit for the debug module but there is a minimum frequency requirement of 20MHz.
Is your design meeting timing? I would expect that even without timing constraints it should have still worked assuming timing was met. - Altera_Forum
My design is based on DE2_70_SD_Card_Audio_Player (from Teriasic's DE2-70 CD). The jtag-uart is running at 50Mhz behined the pipeline_bridge. But I didn't take a look at other timing constraints.
