10 years agoHow can I run program on external SRAM?
Dear, In my system,there is a 2MByte external SRAM,I have implemented a SRAM interface controller using Qsys, and passed reading and writing test of SRAM from NIOS processor. I want to...
10 years agoI have made SRAM access successfully. Tips below:
1.SRAM interface shall support byte access. 2.I make use of Avalon_mm interface directly,do not use tristate-bridge. 3.make sure the SRAM timing is correct,especially write timing
