10 years agohow can i know whether the CFM is big enough for my nios project in max10 ?
hi, i use max 10 internal configuration. the device is 10M08, it i use nios + sdram, so i should download the both the hardware and software configuration files into the on chip flash. so, how ...
10 years agothanks!
in the max10 fpga device datasheet.pdf, i find the uncomperssed raw binary file is 1880000 bits, that is 0x395f8 bytes, 19 KBytes program size (code + initialized data)=19*1024=0x4c00 0x4c00 + 0x395f8=0x3 E1F8 should this be smaller than CFM0(2240kb,280KB)? what is the 0x0003F68F? what is the ICB?
