16 years agohow can i get linux used in nios2
rt.
wget http://www.niosftp.com/pub/linux/nios2-linux-20100621.tar can not work4 Replies
hi,I have the same problems. There may be some wrong with the server. You may get a lower version on the Internet. good luck.
wangweike - Altera_Forum
you must be chinese.
try a mirro,http://sopc.et.ntust.edu.tw/pub/linux/nios2-linux-20100621.tar - Altera_Forum
does nios-linux-20100621 support DE2-70 board?
there are only two choices 3c120 or NEEK - Altera_Forum
--- Quote Start --- does nios-linux-20100621 support DE2-70 board? there are only two choices 3c120 or NEEK --- Quote End --- it support it refer to the nioswiki,and you can creat the system for your board
