12 years agoHow can I get data from FPGA frabic via FPGA-to-HPS?
Hello, I implement the a soft-IP AXI master in FPGA and transmit the data to HPS side via FPGA2HPS bridge, I set ACP-port as "dynamic" mode. BUT how can I read the data via DS-5 program registe...
12 years agoHi scozart,
Thank you for your reply! But my question is that I cannot get data from fpga2hps bridge via Arm-Linux Application. In my design, the following steps I used in my project: 1. The FPGA master have been implemented in FPGA2HPS bridge, I used the signals (user sideband signal, write address signal, write address valid signal, write data signal, write data valid signal ) 2. In ARM side, I use the ACP ID Mapper Register. The dynrd and dynwr registers has been set the 5-bits user(according to user sideband signal) and 2-bits Page(I remap the 3rd 1GB memory). 3. I maped the address in Linux application , access to e.g. 0x80004000 (3rd page) address, but the data have not changed . Did I miss some steps? Or misunderstand something?
