22 years agohow can i develop a programme which control lcd?
I want to develop a programme to control the lcd,but i don not know how to start. who can help me?
20 years ago#include <linux/module.h># include <linux/errno.h># include <linux/cdev.h># include <linux/config.h># include <linux/types.h># include <linux/errno.h># include <linux/miscdevice.h># include <linux/slab.h># include <linux/ioport.h># include <linux/fcntl.h># include <linux/mc146818rtc.h># include <linux/netdevice.h># include <linux/sched.h># include <linux/delay.h>
# include <asm/io.h># include <asm/uaccess.h># include <asm/system.h># include <linux/delay.h> # define LCD_On 1# define LCD_Off 2# define LCD_Clear 3# define LCD_Reset 4# define LCD_Cursor_Left 5# define LCD_Cursor_Right 6# define LCD_Disp_Left 7# define LCD_Disp_Right 8# define LCD_Get_Cursor 9# define LCD_Set_Cursor 10# define LCD_Home 11# define LCD_Read 12# define LCD_Write 13# define LCD_Cursor_Off 14# define LCD_Cursor_On 15# define LCD_Get_Cursor_Pos 16# define LCD_Set_Cursor_Pos 17# define LCD_Blink_Off 18 # define kLCD_IR na_led_green# define kLCD_DR (na_led_green + 8) # define LCDWriteData(x) outl(x , kLCD_DR)# define LCDWriteInst(x) outl(x , kLCD_IR) # define LCDReadData inl(kLCD_DR)# define LCDReadInst inl(kLCD_IR) # define Major 250 static int Device_Open = 0; static int lcd_16207_ioctl(struct inode *inode,struct file *filp, unsigned int cmd,unsigned long arg); static int lcd_16207_open(struct inode *inode,struct file *filp) { static int counter = 0; if(Device_Open)return -EBUSY; Device_Open++; printk("You have open the device %d times\n",counter++); return 0; } static int lcd_16207_release(struct inode *inode,struct file *filp) { Device_Open--; printk("You have release the device\n"); return 0; } static int lcd_16207_ioctl(struct inode *inode,struct file *filp, unsigned int cmd,unsigned long arg) { volatile unsigned long display; switch (cmd) { case LCD_On: if (copy_from_user (&display, (unsigned long *) arg, sizeof(display))) return -EFAULT; LCDWriteInst(display); break; case LCD_Off: if (copy_from_user (&display, (unsigned long *) arg, sizeof(display))) return -EFAULT; LCDWriteData(display); break; default: return -EINVAL; } return 0; } static struct file_operations lcd_16207_fops={ .ioctl = lcd_16207_ioctl, .open = lcd_16207_open, .release = lcd_16207_release, }; static int lcd_16207_init(void) { int ret = register_chrdev(Major,"LCD_PIO",&lcd_16207_fops); if(ret<0) { printk("Registering the device failed with %d\n",Major); return Major; } printk("You have init Device %d\n",Major); return 0; } static void lcd_16207_exit(void) { if(unregister_chrdev(Major,"LCD_PIO")) printk("exit failed"); } module_init(lcd_16207_init); module_exit(lcd_16207_exit); MODULE_AUTHOR("Andrew Bose"); MODULE_LICENSE("GPL");
