12 years agohow can i access the output
my custom logic takes 26 clk cycles to produce the output, how can i access the output just it finish processing the inputs.
12 years ago --- Quote Start --- but my logic is pipelined, and have an input each clk, is ther any function that can use as a timer in c, instead implementing it in vhdl. --- Quote End --- You don't need a timer - you're only going to wait 26 clocks. I used a macro that did memory reads to get me the number of clocks to stall before reading:
#define WAIT_CLKS() do { volatile int x, *y = &x; (void) *y; (void) *y; (void) *y; } while(0) Use a scope to figure out how many reads from *y you need to wait 26 clocks and simply use this macro where you want a write, wait, read sequence. BillA
