AAlas3
6 years agoHost File System not working
Hey, I built a simple Qsys system with Nios inside it and I would like to write and read from file in host machine, so I wrote the following: #include "stdio.h" #include "alt_sys_init.c" int main...
Ahmed_H_Intel1
6 years agoHi,
Please first, make sure you enable the altera_hostfs package by opening the BSP editor>>Software Packages tab>> Check the box in front of the altera_hostfs package.
Next is a sample code to read and write to a file at the host:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define BUF_SIZE (50)
int main(void)
FILE= fp_ascii = NULL;
FILE = fp_bin = NULL;
char buffer[BUF_SIZE];
int read_size=1;
/* Reading ASCII File from the host*/
fp_ascii = fopen("file path", "r");
if (fp_ascii == NULL)
printf("Cannot open the file\n");
exit(1);
fgets(buffer, sizeof(buffer), fp_ascii);
printf("%s", buffer);
fclose(fp_ascii);
/* WriteASCII File from the host*/
fp_ascii = fopen("file path", "w");
exit(1);
strcpy(buffer, "Hellow from NIOS II");
fputs(buffer, fp_ascii);
fclose(fp_ascii);
return 0;
}Regards,
- AAlas36 years ago
It is enabled, anyway I solved the problem: In code when you fopen a file you should write "/mnt/host" with the file path and the pointer will locate the project directory
By the way my name is Ahmad and it is pleasure sir to meet you
- Yogesh6 years ago
So suppose there is a read.txt file in project directory along side main.c code with path as below :
E:/folder1/project/read.txt
What should path of read.txt shd be in main.c file?
mnt/host/read.txt ???
