19 years agoHost based and Read only Zip files
Hi all,
I got a certain code that I need to run having an input file. I download my program to RAM in general and just use the flash for the file when using the "rozipfs". I tried using once the host based file system and the other time the zip file and I used the performance counter to track a function that does NOT have any access to files in it. I got a difference of 40 million clocks between both results. What's the reason inspite of having no relation to file opening or samples' calling in the meant function ? And another thing too, in general which is faster the host-based system or the "rozipfs" ? (meaning JTAG or flash memory) Thanks in advance2 Replies
Flash/rozipfs will be much faster. Hostfs is going over a GDB link to your PC.
With respect to your other question, I'm not sure why you're seeing a significant slowdown when using hostfs, however, you'll never be using hostfs in a real-world embedded system, so I can't see that it matters much anyway http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Cheers, - slacker - Altera_Forum
Thanks Slacker for ur reply, u are right regarding the real-time operations but still it puzzles me, try me one last time, I will elaborate for a last time http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
My program is as follows:# include "stdio.h" void filter(int); int main() { MyClass a; a.openMyFile("/mnt/rozipfs/aser.txt"); //function that opens a file stream int data = a.readCurrentInput(); //reads an integer from current data filter(data); //my function that I want to measure its performance } void filter(int) { int y=data; /*continue code normally*/ } /************************************** ***************************************/ I want to measure the performance of "filter(data)" for zip files and host based files. I get more time in case of ZIP FILE system ! I don't know the reason. Thanks
