20 years agohigh-level become 2v!!
hi: i met a very strange phenomenon!
i define a bidir port named daccontrol[1..0],then i write the direction register so that i could define it as a output port, THEN I OUTPUT A "1" TO daccontrol[1] or daccontrol[0],in theory one of them should be3.3v ,another should be 0v,BUT BOTH OF THEM SHOW 2V! I have tried many times! when i write "1" to both daccontrol[1] and daccontrol[0],they show right! so is the data[0]! thanks !! with my regards!2 Replies
--- Quote Start --- originally posted by wbqyy@Dec 21 2005, 08:10 PM hi: i met a very strange phenomenon!i define a bidir port named daccontrol[1..0],then i write the direction register so that i could define it as a output port, then i output a "1" to daccontrol[1]
or daccontrol[0],in theory one of them should be3.3v ,another should be 0v,but both of them show 2v!
i have tried many times! when i write "1" to both daccontrol[1] and daccontrol[0],they show right! so is the data[0]!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11706)
--- quote end ---
--- Quote End --- There could be a number of things here: contention (something else attempting to drive that signal low), some large current sink attached to the I/O, etc. Another possibility is that Altera FPGAs offer many choices for I/O standards for each pin; they can be programmed to operate at different voltages, using a combination of I/O bank power supply voltage, and settings inside Quartus II. To make sure this is not the problem, open Quartus II assignment editor and look for any assignments for I/O standard regarding the pin(s) in question. I believe that the 'LVTTL' standard is the default, which on our dev boards wil provide 3.3V at logic '1'. Again though, please do check for other hardware contention/current drain issues.
The IO direction may not working. So all the pins are Hi-Z input mode.
Make sure the access is "uncached". Or try change the bidir port to a output only port, can help to identify the problem.
