15 years agohelp:no sdram how to nois debug?
hello: There is a problem,in the dk_dev_3c120n development board. it has tow sram and flash ,but no sdram. how can i debug on nios2! I try to use on-chip memory,but the depth...
15 years agoIf you use the small library/driver versions you should be able to get something that will fit in the internal memory.
You should also be able to use the sram (I've no idea how big that might be!).
