20 years agoHelp writing c code for NiosII_Stratix II_2s60
Hi at all! This is my first post. I would like to have some advice to write the c code for my thesis. I have to use a NiosII_Stratix II_2s60. I have started from the example present in kits/nios...
SS5
8 years agoHi,
I am stuck in one design for past 10 days. Working with Altera CYCLONE V FPGA board.
I am generating Trigger Signal for 500ns and 32-bit counter (Verilog), and at every (neck edge) positive edge of Trigger signal i need to collect and store that count data into reg (final_value).
Same thing, the counter is connected to FIFO and sends repeatedly bits to fill the FIFO that is connected to Nios.
Enable signal is given From PIO., and reading the counter data from NIOS
ISSUE: IN NIOS, same data printing continously for certain number of times.
Verilog Code
module Counter(
input clk, // 50Mhz
input enable,
input reset,
output reg[31:0] Final_value,
output reg trig
reg[31:0] counter_out;
reg [7:0] temp=0;
reg [31:0] counter_result;
wire temp1;
wire temp2;
always@(posedge clk)
begin
if(reset)
begin
trig<=0;
temp<=0;
counter_out<=0;
end
else if (enable==1'b1)
begin
counter_out<=counter_out+1;
temp<=temp+1;
if(temp==25)
begin
temp<=0;
trig<=~trig; /// Generating COunter
end
end
end
assign temp1=trig;
assign temp2=temp1&&clk;
always@(posedge temp2)
if(reset)
counter_result<=0;
else
begin
counter_result<=counter_result+1; // Increaming the Counter
end
always@(posedge trig) // Detecting Edge trig and storing into Final_value
if(reset)
Final_value<=0;
else
begin
Final_value<=counter_result;
end
endmoduleBlock Design
NIOS console
