15 years agoHelp with USB Blaster using linux SUSE 11.3
I am using SUSE 11.3 and trying to get the Quartus II programmer to recognize the USB Blaster.
Currently, the programmer does not recognize the USB Blaster under Hardware Setup. I have tried the following procedure without success with my board powered up and usbblaster connected to the board and the usb port on linux machine: 1. Added the following lines to the file "51-usbblaster.rules" file under /etc/udev/rules.d: BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", PROGRAM="/bin/sh -c 'K=%k; K=$${K#usbdev}; printf /proc/bus/usb/%%03i/%%03i$${K%%%%.*} $${K#*.}'", RUN+="/bin/chmod 0666 %c" BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6002", MODE="0666", PROGRAM="/bin/sh -c 'K=%k; K=$${K#usbdev}; printf /proc/bus/usb/%%03i/%%03i$${K%%%%.*} $${K#*.}'", RUN+="/bin/chmod 0666 %c" BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6003", MODE="0666", PROGRAM="/bin/sh -c 'K=%k; K=$${K#usbdev}; printf /proc/bus/usb/%%03i/%%03i$${K%%%%.*} $${K#*.}'", RUN+="/bin/chmod 0666 %c" 2. Added following line in /etc/init.d/boot.local /home/bin/altera/10.1/quartus/bin/jtagd 3. mkdir /etc/jtagd 4. cp /home/bin/altera/10.1/quartus/linux/pgm_parts.txt /etc/jtagd/jtagd.pgm_parts 5. touch /etc/jtagd/jtagd.conf 6. /home/bin/altera/10.1/quartus/bin/jtagconfig The result: No JTAG hardware available Any help would be appreciated.3 Replies
The following helped me to get the USB Blaster running on Ubuntu 10.04, it might help you too. Also there are quite a few threads about similar problems on various distributions here in the forum, so you might want to try a search.
I needed to remount the /dev/bus "filesystem" to /proc/bus as the Altera jtag tools seem to have the paths in /proc/bus/usb hardcoded. I put the following in my /etc/rc.local so it gets exectuted on every boot, don't know whether it works the same on SuSE, but there surely is an option to run commands on boot there too:
HTHmount --bind /dev/bus /proc/bus ln -s /sys/kernel/debug/usb/devices /proc/bus/usb/devices - Altera_Forum
I found a solution to my problem:
mkdir -p /dev/bus/usb/.usbfs mount -n -t usbfs usbfs /dev/bus/usb/.usbfs -obusmode=0700,devmode=0600,listmode=0644 ln -sf /dev/bus/usb/.usbfs/devices /dev/bus/usb/devices mount --rbind /dev/bus/usb /proc/bus/usb - Altera_Forum
Thanks tklauser
