15 years agoHelp with interrupts
I've started learning NiosII. And I would like to know about interrupt handling.. Is there any useful article in the net that I could refer to?? the function of my code is to blink a led at 1Hz using a given 100Hz input. plzz help... Thanx. :-P2 Replies
The subject you're intersted in is explained in the Excpetion Handling chapter http://www.altera.com/literature/hb/nios2/n2sw_nii52006.pdf In fact the interrupt is a kind of exception. Anyway you should forecast to spend some time to read some other chapters of the NiosII documentation, as they are interconnected. http://www.altera.com/literature/lit-nio2.jsp This is not a "RTFM"-like answer: I, myself, learned reading the manuals. Sometimes the problem is where to find the correct manual. Regards, Gabriele - Altera_Forum
thanx.
I'l go through the links u've posted and check it. :) True indeed, because there's so many manuals we have to spend lots of time going through every one of them. Thanx for ur help.
