13 years agoHelp uClinux
Please help me
I want to install uClinux (2.6.9) on Cyclone 3 EP3C25F324C8, following the tutorial "http://scorpius.homelinux.org/~marc/nios2.html".
When i arrive at the command "make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=/home/nastri/nios/sopc.ptf" for the kernel configuration, there would be a list of hardware resources of my Nios system, but the list is empty (under "Please select a device to upload the kernel to:"). In the following it can be observed the problem in the Linux (Debian) shell. "nastri@debian:~$ su Password: root@debian:/home/nastri# export PATH=$PATH:/opt/nios2/bin root@debian:/home/nastri# cd linux-2.6.9 root@debian:/home/nastri/linux-2.6.9# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=/home/nastri/nios/sopc.ptf no emulation specific options. RUNNING hwselect --- Please select which CPU you wish to build the kernel against: (1) cpu - Class: altera_nios2 Type: s Version: 7.08120 Selection: 1 --- Please select a device to upload the kernel to: Selection:" Regards - Altera_Forum
Please help me, i have some problems compling the nios2 toolchain
I want to install uClinux (2.6.9) on Cyclone 3 EP3C25F324C8, following the tutorial "http://scorpius.homelinux.org/~marc/nios2.html". When i arrive at the command "make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=/home/nastri/nios/sopc.ptf" for the kernel configuration, there would be a list of hardware resources of my Nios system, but the list is empty (under "Please select a device to upload the kernel to:"). In the following it can be observed the problem in the Linux (Debian) shell. "nastri@debian:~$ su Password: root@debian:/home/nastri# export PATH=$PATH:/opt/nios2/bin root@debian:/home/nastri# cd linux-2.6.9 root@debian:/home/nastri/linux-2.6.9# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=/home/nastri/nios/sopc.ptf no emulation specific options. RUNNING hwselect --- Please select which CPU you wish to build the kernel against: (1) cpu - Class: altera_nios2 Type: s Version: 7.08120 Selection: 1 --- Please select a device to upload the kernel to: Selection:" Regards - Altera_Forum
I want to install uClinux (2.6.9) on Cyclone 3 EP3C25F324C8, following the tutorial "http://scorpius.homelinux.org/~marc/nios2.html". When i arrive at the command "make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=/home/nastri/nios/sopc.ptf" for the kernel configuration, there would be a list of hardware resources of my Nios system, but the list is empty (under "Please select a device to upload the kernel to:"). In the following it can be observed the problem in the Linux (Debian) shell. Pratically: nastri@debian:~$ su Password: root@debian:/home/nastri# export PATH=$PATH:/opt/nios2/bin root@debian:/home/nastri# cd linux-2.6.9 root@debian:/home/nastri/linux-2.6.9# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=/home/nastri/nios/sopc.ptf no emulation specific options. RUNNING hwselect --- Please select which CPU you wish to build the kernel against: (1) cpu - Class: altera_nios2 Type: s Version: 7.08120 Selection: 1 --- Please select a device to upload the kernel to: Selection: (but there aren't options to choose)" Regards - Altera_Forum
Posting the same question multiple times won't get you more answers. Did you read the documents indicated by mschnell?
i met it too
i just added a cfi and solved it i think 20070130 do not support spcs as good as cfi minimum sopc modules for nios-ucLinux : nios2 f sdram (>8MBs) JTAG UART EPCS controller timer (full featured) CFI (even you don't have any flash memory in your board,and my DE0 don't,too,you just use it at your sopc ) - Altera_Forum
Hi
Please also check this thread http://www.alteraforum.com/forum/showthread.php?t=39964&p=164765#post164765 - Altera_Forum
Hi Sen_Han... maybe a bit late for a question to your respond - but worth a try :)
Yesterday I run into the same problem with my DE0-Nano: on a new uClinux download <make hwselect> asks for a CFI memory to upload the kernel to. In an older download version of uClinux this selection was not necessary (only CPU and execution device was asked for). So I will follow your advise and add a CFI to the SOPC-builder (Quartus II v10.1), I just wonder about the paramter settings and connections - any special set-up of this dummy/CFI ? Many thanks..
