13 years agoHelp uClinux
Please help me
13 years agoI want to install uClinux (2.6.9) on Cyclone 3 EP3C25F324C8, following the tutorial "http://scorpius.homelinux.org/~marc/nios2.html".
When i arrive at the command "make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=/home/nastri/nios/sopc.ptf" for the kernel configuration, there would be a list of hardware resources of my Nios system, but the list is empty (under "Please select a device to upload the kernel to:"). In the following it can be observed the problem in the Linux (Debian) shell. "nastri@debian:~$ su Password: root@debian:/home/nastri# export PATH=$PATH:/opt/nios2/bin root@debian:/home/nastri# cd linux-2.6.9 root@debian:/home/nastri/linux-2.6.9# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=/home/nastri/nios/sopc.ptf no emulation specific options. RUNNING hwselect --- Please select which CPU you wish to build the kernel against: (1) cpu - Class: altera_nios2 Type: s Version: 7.08120 Selection: 1 --- Please select a device to upload the kernel to: Selection:" Regards
